Automatic trans/Torque Convert Whine?
Old Feb 28, 2006 | 08:36 PM
корвет's Avatar
корвет
Default Automatic trans/Torque Convert Whine?
A very noticable whine is heard from the AT area whilst in any drive gear.
The noise is similiar to a power steering pump low on fluid.
Suggestions?
Old Feb 28, 2006 | 08:52 PM
Lichen's Avatar
Lichen
Was it recently rebuilt? Did you change gears in the differential? Doesn't sound normal. Mine is as quiet as a nun ( oops, I mean mouse, Lent begins in a few hours).
Old Feb 28, 2006 | 09:05 PM
Pete K's Avatar
Pete K
Some models make a slight buzzing noise. A regulator valve mod fixes that. I mod every one I build. A whining noise could be a pump or converter problem.
Old Feb 28, 2006 | 11:18 PM
корвет's Avatar
корвет
No rebuild, trans fluid changed once at 100K. Trans now has 120K.
Old Feb 28, 2006 | 11:29 PM
Corvette0096's Avatar
Corvette0096
With the car running and in park, lift up the detent cable and see if it gets louder.
To Automatic trans/Torque Convert Whine?
