Led Chmsl
Old Feb 28, 2006 | 10:56 PM
rightofway's Avatar
rightofway
Default Led Chmsl
anyone got any places to buy an LED CHMSL or the LED bulbs that replace the incandecents that i've seen for some cars
or even a diy for making one
tia
Old Feb 28, 2006 | 11:03 PM
96fastvette's Avatar
96fastvette
im not sure you could do it yourself because i believe the chmsl works on a certain amount of current, and the led's dont flow enough..... you would need to use some type of circuit board and that goes way beyond most diyourselfers
Old Mar 1, 2006 | 01:38 AM
Slalom4me's Avatar
Slalom4me
From a recent post in Autocrossing & Racing
Wiring harness for C4 trailer?
Originally Posted by Slalom4me
I didn't know about LED replacements for the 1157 (and others)
Judging from this link, they aren't crushingly expensive and if they
eliminate the need for the adapter box, they are a deal. The site
displays a wide variety of replacements - the number of LEDs seems
to be the main difference. I suppose that physical size and current
draw are the limiting criteria to how powerful a LED to choose. Elsewhere
on the site, there is information about current draw, intensity and
other parameters of interest.
Thanks for putting these on my radar.
Old Mar 1, 2006 | 08:30 AM
kalister1's Avatar
kalister1
tia
I hate to sound stupid, but OK what is CHMSL?
Old Mar 1, 2006 | 08:48 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Center High mounted something light, 3rd brake light.
Old Mar 1, 2006 | 07:56 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Me too!!!
If I have any CHMSL's I ain't never changed the filters on'em.
Old Mar 1, 2006 | 08:09 PM
rightofway's Avatar
rightofway
Originally Posted by VetNutJim
Me too!!!
no filters just regular old turn signal fluid
bluewasp was close S=stop
anyone happen to know the bulb numbers?
Old Mar 1, 2006 | 09:54 PM
CorvAdel's Avatar
CorvAdel
Can only help with after-market nos. on a box I bought quite a few years ago....Sylvania 891..on the packet it states..."High Mount Stop". If I remember correctly, these were a lot cheaper than the ones from C. Cent., MAD, etc..
Old Mar 1, 2006 | 10:04 PM
_twisted_'s Avatar
_twisted_
and they arent cheap, almost same $ as the dig disp 882's
Old Mar 2, 2006 | 10:45 AM
96fastvette
i believe they are actually a halogen-type blub too...not just an incadescent, like most mini bulbs, so you are not soposed to touch the glass. i havent seen one in awhile though, so i may be wrong.
Old Mar 2, 2006 | 11:06 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
In case fastvette's wording confuses some CF'ers, a halogen bulb is one type of incandescent bulb.
I think he meant that, but the way it reads could be misinterpreted.
Plus, his spelling is atrocious.
Larry
code5coupe
Old Mar 6, 2006 | 08:20 PM
96fastvette
sorry about the obvious typo's but yes you are correct the halogen is an incandescent bulb, however the point i was trying to make is that it is like a headlamp bulb, so you cant touch the glass or the grease from your fingers will cause a different rate of expansion and contraction across the surface of the bulb, causing it to prematurly fail...
To Led Chmsl
