Brake booster (again)
Old Mar 1, 2006 | 09:11 AM
mitchcole's Avatar
mitchcole
Default Brake booster (again)
So, a couple weeks ago, I replaced the original booster with a rebuilt unit from autozone. It took forever to change out, and the brake pedal was significantly lower.
So, I bought the metal one that all you guys were referring to and installed it last night (I'm getting pretty good at this now.)
It does fit perfectly and I like the Cadmium? plating on the metal housing. http://www.hotrodsusa.com/store/product341.html
So - I'd recommend the less expensive, proper fitment aftermarket booster made of metal...
Old Mar 1, 2006 | 09:15 AM
rick lambert's Avatar
rick lambert
and they certainly can take the heat better than those plastic puppies!
Old Mar 1, 2006 | 09:59 AM
Carl Johansson's Avatar
Carl Johansson
Sorry I got the information on hotrod USA's product to you after you bought the other one - but at least you have it right now - (I like the metal finish also - and after 6 months see no evidence of rust)
So bring your baby down to Atwater March 19th - run an autoX and really test out those brakes! It only costs 30 bucks - alot of fun for the money!
Carl Johansson
Old Mar 1, 2006 | 11:07 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
When mine goes ****-up, metal it is!
Old Mar 1, 2006 | 08:19 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
...it is a pain huh?!
...glad for you that you can use metal version...
on BlackSheep (1995) I had with black plastic version...
The Metal version would not work...(apparently for earlier models)
...but I havent had to replace in 4 weeks now
Old Mar 2, 2006 | 05:41 AM
mitchcole's Avatar
mitchcole
At least Autozone didn't give me any crap for returning the part.
To Brake booster (again)
