Cable Routing Question -- SR Installation
Old Mar 1, 2006 | 10:27 PM
90Indy's Avatar
90Indy
Default Cable Routing Question -- SR Installation
I need advice on routing the throttle, cruise control and tv cables when installing the SR Plenum. I downloaded the instructions (I bought the setup used) and it appears I am to run the tv cable under the plenum and the other cables over the plenum. Is this correct?
If it is, I am having a difficult time getting all three bracket bolts to line up as the tv cable is pressing very hard against the plenum. How have you overcome this situation? I could cut, modify and reweld the bracket but if I am missing something simpler I would appreciate an alternative.
Thanks for any input.
90Indy
Old Mar 1, 2006 | 10:41 PM
Corvette0096's Avatar
Corvette0096
