tire upgrade
Old Mar 2, 2006 | 03:56 AM
LeeJohns's Avatar
LeeJohns
Navigator
Default tire upgrade
New 1995 vette owner
I am looking to upgrade my tire size on my vette...what can I go to factory rims.....If I have to chg wheel size any suggestion?
Old Mar 2, 2006 | 09:08 AM
aminnich's Avatar
aminnich
Go to the zr1 rims, there is set in the the parts sale/wanted section right now.
Old Mar 2, 2006 | 09:44 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Take a look at the search function; there've been many posts about this. But, as a starter you can go easily to 9.5" all around. Or you can do 9.5" up front and 11" in rear with tire sizes of 285-40 front and 315-40 rear. Depending on the actual size of the tire, the 315 may or may not rub a little and it may stick out a bit from the fender in the rear.
Old Mar 2, 2006 | 10:32 AM
MYCoupe's Avatar
MYCoupe
More than likely you have the standard 17x8.5" F and 17x9.5" R wheels. If you want to stay on the cheap side then just find another set of 17x9.5" wheels for the front. This way you can run 275/40/17 or 285/40/17 tires all around with the added benefit of being able to rotate them. Good luck!
Old Apr 3, 2006 | 10:20 AM
jonkc4's Avatar
jonkc4
Is there any way to check the wheel size by finding a stamp on the wheel,etc. or is the only way to determine size by measuring the wheel once the tire is off the wheel? My wheels are the 5-spoke design.
Old Apr 3, 2006 | 02:47 PM
shotchkiss's Avatar
shotchkiss
May factory wheels had the size cast into the back of one of the spokes, if I remember right.
To tire upgrade
