ASR shutdown with ASR turned off?
Old Mar 3, 2006 | 04:23 PM
lt4red's Avatar
lt4red
Default ASR shutdown with ASR turned off?
I have a 96 lt4. It is an intermittent problem, but here goes. Sometimes when I shut the asr off to allow some "fun" I get what feels like a complete shutdown of the motor. It lasts for only a split second and then comes back strong. It has only happened to me in a tire spinning situation with the asr turned off and with the asr on it never completely shuts down. It just pushes the throttle back at me like it should. When this happens, if feels like a fuel shutoff, or the ignition cutting out, but still, only happens if the asr is shut off. It is also not the rev limiter, because i'm not even to 6k yet when it has happened. Any ideas would be appreciated. Thanks in advance.
Old Mar 3, 2006 | 06:11 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Did this by any chance occur at about 4500rpm at wide open throttle in second gear???
Larry
code5coupe
Old Mar 3, 2006 | 06:30 PM
lt4red's Avatar
lt4red
Larry
code5coupe
It has only happened in first, that I can remember, but i'm intrigued by you querey, please explain. It has only been at wide open throttle.
Old Mar 3, 2006 | 09:17 PM
drochau's Avatar
drochau
Do tell me what your oil pressure reads when the problem occurs...
Old Mar 4, 2006 | 12:48 AM
lt4red's Avatar
lt4red
MY oil pressure is always between 30-70psi. I have not however looked at the pressure when this occurs. I will try to remember to look the next time. Do you think that the oil pressure safety could be shutting down the fuel pump?
Old Mar 4, 2006 | 12:58 AM
drochau's Avatar
drochau
Give her a look and let me know, I went though some serious work to fix my problem and it started similar to yours.
Old Mar 14, 2006 | 12:37 PM
lt4red's Avatar
lt4red
Finally got a chance to play around with the car, and the oil pressure stays good when this happens. I think I may have figured out the problem however. I don't want to jinx myself, but I never paid attention to the fuel level when this would happen. I think with the asr turned off, it would allow enough g-force to expose the fuel pump under hard acceleration, and low fuel in the tank. When I took it out today it would stall everytime on a hard take off with the asr turned off. I put some gas in it and could not get the problem to repeat. I would think that the tank is baffled enough to prevent this, but perhaps not. Any way, keep your fuel levels up..
Old Mar 14, 2006 | 12:52 PM
bumpnzx3's Avatar
bumpnzx3
From: Edwardsville, Illinois 88 stroked s10, 92 stock 6spd
the whole time i was reading this i was thinking that same thing- low on gas. mine does the same thing with an 1/8 tank or less- asr on or off.
Old Mar 14, 2006 | 04:05 PM
4REGT4's Avatar
4REGT4
Yeah - mine will even do this with 5 bars showing on the fuel gauge. Just about every C4 seems to have a faulty gauge.... I have seen the fix posted a few times... But it doesn't bother me enough (I have gotten used to reading past its inaccuracy).
To ASR shutdown with ASR turned off?
