Roll cages?
Old Mar 5, 2006 | 12:44 AM
C4forlife's Avatar
C4forlife
Default Roll cages?
Does anybody have any pics of their rollcage and close ups of the mounting points? I am still debating between just getting a DRM four point or going to a fabricated six point.
Old Mar 5, 2006 | 12:46 AM
mrc24x's Avatar
mrc24x
Check my pics. 6 pt w/ nascar bars.
actually my previous posts....
Old Mar 5, 2006 | 01:33 AM
STL94LT1's Avatar
STL94LT1
My R-D Racing's S/T Frame Support.
Old Mar 5, 2006 | 01:45 AM
pablocruise's Avatar
pablocruise
How are you guys attaching the mounting points of the rollcage to the car? Welding the tube directly to the frame?
I'm doing my cage right now also(still) but don't know how to go about this part.
Old Mar 5, 2006 | 08:23 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The R-D roll bar has flanges that bolt to the integral bulkheads behind the doors and in the rear to the frame rails. It can be bolted in w/ the provided nutserts and/or welded in if needed or desired.
Old Mar 5, 2006 | 09:55 AM
c4cruiser's Avatar
c4cruiser
The R-D S/T Frame Support is well made and not too difficult to install with the bolt-in process But it has to be welded in place to make it legal for SCCA competition (like any other cage).
Old Mar 5, 2006 | 11:33 AM
CFI-EFI's Avatar
CFI-EFI
A base roll cage begins with 8 points. Anything less is merely a roll bar. You would be wise to consult with the tech division of what ever sanctioning body you plan to compete in, before you spend a lot of time, effort, and money, on something they won't accept for your planned endeavors. Some companies sell items with different product names, for a reason. For instance, early on, those pretty chrome bars in a pick up bed were referred to as roll bars. Later they were marketed as "bed bars" or "show bars", because they provided little or no, real rollover protection. If it is just for show, check with your wife or girl friend. If it is for competition, have your tech dept give it the OK.
RACE ON!!!
Old Mar 5, 2006 | 12:06 PM
85 500 horse's Avatar
85 500 horse
Installation isn't that bad. Just time consuming. The mandatory tool here is the grinder. Without it, you're out of luck. You can affix the cage/bar (mine's a rollbar) to the frame with bolts, but the proper and best method is welding it.
Mine's welded and you can never tell. I replaced the carpet when I did my bar. I also painted it to make it look that much nicer.
Old Mar 5, 2006 | 03:30 PM
Slalom4me's Avatar
Slalom4me
More info here
Old Mar 5, 2006 | 06:07 PM
mrc24x's Avatar
mrc24x
These are a little better at showing the mounting pts. My setup isn't too user friendly but should do the job if (when) I need it.
Old Mar 5, 2006 | 06:40 PM
CFI-EFI's Avatar
CFI-EFI
THAT is a cage!
RACE ON!!!
Old Mar 5, 2006 | 09:55 PM
rightofway's Avatar
rightofway
Originally Posted by CFI-EFI
THAT is a cage!
RACE ON!!!
Old Mar 5, 2006 | 10:35 PM
Gary04Z06's Avatar
Gary04Z06
R-D Racing 4-point in my sig pic. Install wasn't to bad.
Old Mar 6, 2006 | 08:57 AM
hardlight's Avatar
hardlight
I'm a another satisfied R-DRacing S/T Frame roll bar user. If you put a real roll cage in a C-4 you'd better be as limber as a monkey to get in and out. Even if you had a removeable bar on the drivers side it would be a major PITA getting in and out, not to mention your wife or girlfriend on the other side.
Old Mar 7, 2006 | 12:16 AM
HvyHitr's Avatar
HvyHitr
Convertible owners care to chime in here? I have yet to find a IHRA legal roll bar that ALSO lets the top fucntion properly. If you have a vert with bar please post some pics.
Old Mar 7, 2006 | 09:41 PM
hardlight's Avatar
hardlight
Here is a deal for you over in C-4 Parts for sale or wanted....
http://forums.corvetteforum.com/show...69&forum_id=55
Old Mar 7, 2006 | 09:45 PM
C4forlife's Avatar
C4forlife
Im not worried about the wife/ girlfriend situation much. Probaly because my passenger seat has been removed and a coleman cooler installed in its place (long road trips) Anyway i've been looking at some of the original Corvette Challenge setup. With the proper upgrades to meet new rules this should work out very nicely but I will consult an experienced chassis fabricator before any work is done.
To Roll cages?
