are ball joint dust boots replacable?
Old Mar 5, 2006 | 03:11 PM
turbodu's Avatar
turbodu
Default are ball joint dust boots replacable?
Are ball joint dust boots replacable? Or do I need to replace the ball joints as well? Ecklers or Mooge? Thanks for any help or ideas.
kevin reguera
Old Mar 5, 2006 | 03:58 PM
Pete K's Avatar
Pete K
The only ones I could find were made by Energy Suspension. They are polyurethane.
Old Mar 5, 2006 | 04:02 PM
obnoxus's Avatar
obnoxus
I have actually seen them in "HELP" sections of auto parts stores.
My local Carquest carries them,
Old Mar 5, 2006 | 05:38 PM
subman's Avatar
subman
If you purchase the boots from AutoZone, Kragens, etc., you will need the diminsions: the large end of the boot measures 1 3/8 (could be 1 13/32) the shaft end measures 19/32". I just measured the new polys I got from Ecklers - Part #22769 - $4.99 a set. They are supposed to go on the car today, but I've to many "honey do's" to complete first.Good luck!
Subman
Old Mar 5, 2006 | 11:57 PM
froggy47's Avatar
froggy47
If it's been split for a while, there is probably dirt contamination in the joint. It is recommended by gm to replace the whole ball joint. Your choice.
Old Mar 6, 2006 | 05:03 PM
Vetracr's Avatar
Vetracr
Default Energy boots work well
I've installed Energy Suspension poly boots on the upper ball joints on my 93. They take awhile to seat but work well once seated. Easy and cheap fix!!
Larry
Old Mar 6, 2006 | 05:55 PM
sonomacrew01's Avatar
sonomacrew01
I have the ball joint boot set from energy suspension if you'd like. PM me
To are ball joint dust boots replacable?
