I've got the ignition problem blues ...
I just pulled the codes at Autozone and there are 4:
P0507 - Idle Control System RPM Higher Than Expected (Not sure why this, it never idled high, it idled really low then died)
P0140 - 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2) (Not sure on this, would it cause this kind of roughness?)
P0300 - Random/Multiple Cylinder Misfire Detected (No idea - but i did find that i have a bad plug boot on one cylinder on the passenger side)
P0410 - Secondary Air Injection System Malfunction (I drive around with this code normally - i took off the AIR system when i put headers on)
Any recommendations?? I hope this isn't the damn opti. it has MAYBE 1500 miles on it!
BTW, i cleared the codes and let it idle for a minute. No code has been reset yet. I'm sure that 410 will come back because of the air sytem, but nothing else has been thrown yet. I checked the IAC too, because of P0507, but it is clean.
but they make me wonder if some wiring hasn't been damaged.
I would chase the various harnesses back to the source - chiefly, the O2 sensor and the IAC. Something is amiss. Make sure everything is properly connected and working as intended.
Do you have the FSM? if so, just follow the troubleshooting guides.
