Throw your brake bolts away?
Old Mar 5, 2006 | 09:22 PM
85blkZ51's Avatar
85blkZ51
Default Throw your brake bolts away?
I am taking the brake rotors off and the book says that when you remove the caliper bracket you are to discard the bolts and buy new ones. Is this true? Does anybody else do this? Should I just clean the bolts and use locktite.
Old Mar 5, 2006 | 09:26 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Default Yes
Reuse bolts and use Loctite
Old Mar 5, 2006 | 09:27 PM
Pete K's Avatar
Pete K
I clean them and reuse with locktite. I have read many times to toss them, but never do.
Old Mar 5, 2006 | 09:29 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I did the first time. Some of the bolts (I did brakes at all 4 corners) I had to buy at the dealer... and they were about $7 a piece!!!!!! I don't think that they are true torque-to-yield blots (someone correct me), and I have heard of people cleaning them and reusing them with blue loctite a couple times before they pitch them and buy new bolts.
rightofway's Avatar
rightofway
i did when i overhauled my entire brake assemblies with new pads rotors and calipers but that was because the new calipers came with the pins and bolts, well 3 of them did
Old Mar 5, 2006 | 09:41 PM
redrose's Avatar
redrose
when i first started working on c-4's, back about 20 years ago, the first three or four times i went to the dealer for new brake bolts...then the parts manager asked me what i was doing with em--nobody else ever bought em and they didn't use em in house
Old Mar 5, 2006 | 10:26 PM
dlmeyers's Avatar
dlmeyers
For some good reading, try Google, "torque to yield". Pay close attention to clamping specs on aluminum. Aluminum and I have have never been close.
I've wondered about those bolts. I'd probably use the new ones, unless of course it was Sunday and the dealer was closed.
dlmeyers 90 coupe zf6 3speed shocks
Old Mar 6, 2006 | 01:04 AM
Trog's Avatar
Trog
I have to admit I'm one of the ones who also buys new. Brakes have only been off a couple times in the 12 years I've owned the car. All times were for upgrades... I figure the Helms calls for it & is it REALLY that much $ for peace of mind on the brakes. Which IMHO are one of the last things I want to see fail on the road.
YMMV...
Old Mar 6, 2006 | 07:47 AM
runner140*'s Avatar
runner140*
Two years ago I re-used the bolts and used Loctite on them. If I have to pull them again, they will be replaced. BUT, you are correct, they should be replaced and not reused.
Old Mar 6, 2006 | 08:19 AM
85blkZ51's Avatar
85blkZ51
Before this, the only bolts I ever heard of that were replaced after removal were the rod bolts on the '73,'74 Super Duty 455 Pontiac Trans Ams. I think I'll reuse this time around then when I upgrade the rotors I'll buy new. Thanks
Old Mar 6, 2006 | 09:45 AM
c4cruiser's Avatar
c4cruiser
The reason that the service manual says to toss the bolts and use new is that the new bolts comes with a threadlocker already on the new bolt.
If you clean the threads of the bolts (don't forget to chase the female threads to clean out any residue!!) and apply some blue loctie, you can reuse them. Don't use red loctite as that stuff requires heat to release the material.
The bolts are not a torque-to-yield type but given the high torque setting for the front bolts, it would be a good idea to replace them after a few uses. I go thru a lot of front rotors on my 87 autocross and track day car so I keep an extra set of new bolts in the tool box, but I reuse the front bolts 2 times before tossing.
The rear bolts are not as big a deal as the torque value is nowhere near as high as the front bolts although the bolt is smaller.
Old Mar 6, 2006 | 10:30 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Yeah I agree, I don't believe they are a torque to yield bolt.
I think the major reason why they want you to replace them is they often corrode and get very rough. I've done a few brake jobs before where the pin is actually dipped and very rough from corrosion.
Old Mar 7, 2006 | 08:32 PM
cmontel727's Avatar
cmontel727
I reuse my bolts with blue loctite
Old Mar 7, 2006 | 08:55 PM
96Eric's Avatar
96Eric
Which bolts are we talking about here? The caliper braket mounting bolts?
Old Mar 7, 2006 | 09:35 PM
c4cruiser's Avatar
c4cruiser
He's replacing the rotors so the brackets have to come off.
The service manual also recommends tossing the bolts that hold the caliper guide pins. These are much smaller and torqued to a much lower value, but the factory replacement bolts also have a pre-installed threadlocker on them.
I clean the threads on those bolts and use blue loctite on them just like the caliper brackets.
Old Mar 7, 2006 | 10:50 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Typical GM, throwing out the baby with the bathwater.
I'm going to safety wire my brake bolts if I can find a small drill bit strong enough to cut em.
Old Mar 8, 2006 | 03:32 AM
Casethecorvetteman's Avatar
Casethecorvetteman
If you reuse them and they break, youll know that fable was right!!!
To Throw your brake bolts away?
Old Mar 8, 2006 | 12:23 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
$28 for 4 and piece of mind, heck, not much at all. Just replaced all for rotors/calipers/lines and new bolts.
Old Mar 8, 2006 | 12:27 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
wise move. go over to the autocross/road race section. There's been quite a few track cars that have had thier bolts back off. Steel and aluminum don't mix expansion wise.
Old Mar 8, 2006 | 02:56 PM
75 Red Vert's Avatar
75 Red Vert
I'm a big believer in new bolts and loctite.
2001 Z28 - had brake job done - too busy that time to do it myself. Six months after brake job one of the bolts on the rear caliper mount backed off and fell out. Caliper swung down and scraped the heck out of the inside of my new chrome wheels.
My fault because I didn't check their work.
Use new bolts, torque wrench, loctite = very cheap stopping insurance.
