EGR Valve Gasket with Screen
Old Mar 6, 2006 | 12:49 PM
85C-4's Avatar
85C-4
Default EGR Valve Gasket with Screen
I read in Motor Age that a company had made EGR gaskets with a screen (prevents debris from hitting the EGR pintle area). Has anyone seen one? I unfortunately did not get the name of the outfit when I read the article and can't find teh magazine nor have I found the article on their web site yet. Best regards to all-
85 C-4 4+3
Old Mar 8, 2006 | 10:44 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Which way does the flow go? In the sides, out the center? The center has a nipple extending into the base manifold.
Old Mar 9, 2006 | 01:04 PM
85C-4's Avatar
85C-4
Yes there is an interference issue with this. Some screen/ manifold designs can accomodate a "basket" to fit the screen. I found the company "Tomco" after refining my search a bit and tehy do not make anything for the older (pre 92) valves-
Regards-
Old Mar 9, 2006 | 01:36 PM
Morley's Avatar
Morley
A screen would just give carbon a place to build up and eventually block off the EGR.
Old Mar 9, 2006 | 02:00 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
That's what I was thinking. They do a good enough job of doing that anyway, no sense in speeding up the process.
To EGR Valve Gasket with Screen
