Accel or MSD
Old Mar 6, 2006 | 02:04 PM
sremenap's Avatar
sremenap
Default Accel or MSD
I am putting a SuperRAM on my L98, and have found that previous detonation issues caused by my distro led to a blown head gasket.
My question is when replacing the distro i am leaning toward putting in an accel distro, and getting an MSD ignition box purely based on cost.
Has anyone done this or something similar? Has anyone put an Accel distro in with good luck, or bad luck?
Old Mar 6, 2006 | 05:34 PM
sremenap's Avatar
sremenap
my God guys - how did an entire page of posts come after me and no one commented here.
Is this a touchy subject or something?
Old Mar 6, 2006 | 06:22 PM
CFI-EFI's Avatar
CFI-EFI
Is a "distro" in any way related to a disributor?
RACE ON!!!
Old Mar 6, 2006 | 11:08 PM
pr0zac's Avatar
pr0zac
i haven't really heard anything good about accel ignition products.. have only used the stock distirbutor since going back to efi without issue but i had a complete msd with a pro billet distributor when my camaro was carbed and it worked great never had a problem with it.. now i just have the msd dual plug coil and a 6al and some wires to round off my ignition. i plan to get a new distributor to replace my stock one when i can afford it.
Old Mar 6, 2006 | 11:11 PM
Pete K's Avatar
Pete K
I have been running a stock distributor with an accel module with no issues. The msd box just failed again. I am replacing it with a crane hi 6. Avoid msd 6al if you can. They just don't seem to hold up.
Old Mar 6, 2006 | 11:19 PM
js292's Avatar
js292
i had a 6A on my 70 , all i can say is that the fender next to he box was always hot as hell. Did it make a difference? Not that I could tell.
Old Mar 7, 2006 | 01:41 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
No need to replace the distributor. Waste of money unless yours is worn out. Which is unlikely
I have a MSD 6a, the 8.5mm wires and their coil that fits in the cap. Mounted the box in the left headlight well.
The stock ignition system was running fine. But the MSD was a big improvement.
Old Mar 7, 2006 | 02:08 AM
sremenap's Avatar
sremenap
lol - yeah my distributor is worn out - but from what i see here no one has bought the actual msd distributor.
and yeah - distro means distributor - did you have any advice for me now?
Old Mar 7, 2006 | 02:33 AM
hippy's Avatar
hippy
RACE ON!!!
CFI, is a disributor in anyway related to a distributor?
I'm running a 300+ accel box, it has a built in rev limiter and is a multi spark unit, this is with my stock distributor/disributor/distro. No problems in the 5 years I've had it.
Old Mar 7, 2006 | 02:43 AM
steve1ph2's Avatar
steve1ph2
are you talking about the sr or the distro? after the superram install a few times you will be calling the whole car strange names. iv always used msd. my uncle has always used accel. i think its a "ford or chevy" kind of thing. hey hippy scope my new avtar. its a sr holley double pumper.
Old Mar 7, 2006 | 02:55 AM
hippy's Avatar
hippy
How do you like it?
REDC4CORVETTE's Avatar
REDC4CORVETTE
I have found that if you install the MSD according to the instructions you should not have problems.
I have 2 6AL MSD boxes.
Old Mar 7, 2006 | 03:06 AM
steve1ph2's Avatar
steve1ph2
Originally Posted by hippy
How do you like it?
i dont even have it dialed in yet and it runs like a champ. dude i can set the idle at around 600 to 700 rpms and it purrs like a kitty well kinda lumpy purr tadunt tadunt tadunt. no eye burning fumes or black smoke or soot. im happy so far. seeing the gas squirt in the intake can be a little unnerving $$. but back to the post i also had a msd 6a box and it did crap out on me in about one year. now im just using a msd billet hei with the coil in the cap ( 3 days old ) for me the most simplest two wire hook up tack and hot.
Old Mar 7, 2006 | 03:10 AM
hippy's Avatar
hippy
Glad to hear it worked out for you. Do you miss your SR?
Old Mar 7, 2006 | 03:18 AM
steve1ph2's Avatar
steve1ph2
dont even try it
Old Mar 7, 2006 | 03:21 AM
hippy's Avatar
hippy
dont even try it
Old Mar 7, 2006 | 03:38 AM
steve1ph2's Avatar
steve1ph2
may have to sell it to make way for a pool.
To Accel or MSD
Old Mar 7, 2006 | 07:14 AM
LD85's Avatar
LD85
Many people on the forum have an MSD "A" or "AL" box, they cost @ $215 , a few have the smaller diameter 8366 distributor, they cost @ $250 bucks so you would dump at least $375 to $450 on a package.
http://store.summitracing.com/defaul...2&autoview=sku
They are all plug and play and mostly used for performance engines and some "bling" engines.
A few people have Accell but in general, I think that MSD is preferred I doubt the Accell wold be much less than $200 for the distributor.
My advice, is go get another stock distributor from you local Autozone etc for @ $100 bucks and "forget about it"!
Did you try the search engine yet?
Old Mar 7, 2006 | 11:15 AM
CFI-EFI's Avatar
CFI-EFI
Yeah! Listen to the guy quoted below. Unless you you travel the show circuit, save your money.
RACE ON!!!
Old Mar 7, 2006 | 11:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
Get a stock coil, too so your tach doesnt go nutso at WOT. Im going to throw my MSD coil at a brick wall when Im done with it.
