LT1 cooling system bleeding
Old Mar 6, 2006 | 09:02 PM
mothersworry's Avatar
mothersworry
Default LT1 cooling system bleeding
I have a 92 LT1 and I just added a new 396 stroker motor. I am about to start the engine. What is the correct way to rid the cooling system of air. Is there any tips or tricks you can share? How do you keep water off the engine and opti when bleeding?
Old Mar 6, 2006 | 09:34 PM
CF6873's Avatar
CF6873
Just crack the bleeder screw very little. When you see fluid it means the air is out. I only let a few drops out before I cleaned them up with a towel.
Old Mar 6, 2006 | 09:37 PM
mothersworry
That is what I thought. I read the service manual tonight and it seems straight forward. Just wanted to get some tricks.
Old Mar 6, 2006 | 09:41 PM
Perfusion's Avatar
Perfusion
They're talking about it in this thread right now, too...
Old Mar 6, 2006 | 09:49 PM
mothersworry
Which thread?
Old Mar 6, 2006 | 10:54 PM
Perfusion's Avatar
Perfusion
Originally Posted by mothersworry
Which thread?
Damn...my bad - total bonehead move, huh?
http://forums.corvetteforum.com/show...08&forum_id=34
Old Mar 7, 2006 | 07:42 AM
runner140*'s Avatar
runner140*
With the radiator cap off, bring up to temp. This is the tricky part---With your left hand, add coolant 50/50 mix and with your right hand, rev the engine to about 2000 rpms. Keep adding coolant until full. Then with your left hand put down coolant container and put radiator cap back on. Works every time.
To LT1 cooling system bleeding
