Another GM great - Cooling lines
Old Mar 6, 2006 | 09:55 PM
mothersworry's Avatar
mothersworry
Default Another GM great - Cooling lines
Has anyone changed cooling system hard lines on an lt1 to braided flex? Is there any issues with doing so? to much pressure or creationof pressure? If I am going to spend 100 bucks on cooling lines, they might as well look and perform great. See below picture. I was thinking a few braided flex lines and a ani tee. The only reason I can see for actual hard pipe is that it is close to the engine and they secured it to the side with the cheaply made brackets. Your thoughts?
Old Mar 6, 2006 | 10:41 PM
MYCoupe's Avatar
MYCoupe
Braided lines should work just fine. I saw someone on eBay last week selling a braided kit for the LT1s, but I'm not sure exactly what lines were included.
Old Mar 6, 2006 | 11:27 PM
Powerdrive's Avatar
Powerdrive
After seeing your avatar I forgot the question
Oh yeah..... I think braided lines would work.
One thing to watch....They are very abrasive and over time will create holes wherever they rub. Secure them real well and keep an eye on them over time.... you should not have any problems
Old Mar 7, 2006 | 04:00 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
I'm like powerdrive. Your avatar makes it hard to consentrate on fuel lines!!
Rich K
Old Mar 7, 2006 | 06:19 PM
c4cruiser's Avatar
c4cruiser
The lines only see typical cooling system pressures so there is no reason why a braided line would not work. Add some red and blue anodized covers with clamps and it should look really trick. You could even have some aluminum clamps made up to fit the stock mounting holes.
To Another GM great - Cooling lines
