Rear end RTV
Old Mar 7, 2006 | 06:09 AM
CF6873's Avatar
CF6873
Default Rear end RTV
Does it matter what kind or color of RTV is used on the rear end cover(bat wing). I've seen mostly red or orange being used and I know Right Stuff is good but how about Ultra Black. Will it work with gear lube? Thanks.
Old Mar 7, 2006 | 07:32 AM
chucks88's Avatar
chucks88
I''m a big fan of "The Right Stuff" myself
Old Mar 7, 2006 | 07:43 AM
TA's Avatar
TA
Ditto
Old Mar 7, 2006 | 07:45 AM
Pete K's Avatar
Pete K
I have had bad results with ultra black. I usually use the Ultra copper and it works well. Never used the right stuff. If the ultra copper ever lets me down, I will try the right stuff.
Old Mar 7, 2006 | 08:39 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
The right stuff is the only way to fly.
Let it setup and pray you don't have to take it apart. No it comes apart but you will have to pry it apart and the stuff will stretch till it tears.
Old Mar 7, 2006 | 09:58 PM
CF6873's Avatar
CF6873
Pete, You say you had bad results with Ultra black. I assume that means it leaked? I really didn't want to use Right Stuff because of the difficulty of disassembly in the future. Thanks
Old Mar 7, 2006 | 10:02 PM
Pete K's Avatar
Pete K
I had ultra black fail on a lower intake. I also had a leak in a dana 36 case to batwing seal. I have avoided the right stuff for the same reason. I hears it is rough to get apart. Ultra Copper has never let me down.
Old Mar 7, 2006 | 10:23 PM
MikeC4's Avatar
MikeC4
I would put this stuff in my morning bowl of Wheaties if it wasn't toxic!!
and because it comes in a pressurized can, you can work faster, and have better control of your bead thickness....
Old Mar 7, 2006 | 10:36 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The right stuff. I'm a believer after using it.
There are some pry points on the case, but it was still tough to seperate.
But maybe if your diff doesn't leak, you won't need to replace it.
Old Mar 7, 2006 | 11:23 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Some people walk around work with cell phones on their belts or PDAs, I walk around with a can of the right stuff on mine.
No in all seriousness you can get the stuff apart pretty easily. But 1/2 of what bead was there will be on one half, and the other 1/2 will be on the other. Its good stuff, and yet has failed me. Best thing about it, is it NEVER gets hard or brittle, even in extreme heat situations. I have a glob fall down onto my header collector, and it was only noticable from under the car, so I left it on there. It lasted the entire season/summer of racing and driving on the street and I periodically checked it when the car was up on the lift. It never burned off, and was still very pliable. Not sure what the stuff is made of, but those headers I am sure after a few hundred 1/4 mile passes have seen there fair share of heat!
Old Mar 7, 2006 | 11:32 PM
MikeC4's Avatar
MikeC4
yessirreee !! I bet Orthopedic surgeons use "The Right Stuff" for hip, knee and joint replacements.......
Old Mar 7, 2006 | 11:41 PM
aboatguy's Avatar
aboatguy
Me too!
Old Mar 8, 2006 | 12:31 AM
CentralCoaster
They didnt have any in stock yesterday, so I bought "The Right Stuff - for imports"
What a marketing scam. I suppose it'll leak if I put it on my corvette.
Old Mar 8, 2006 | 12:44 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It tastes like rice
Old Mar 8, 2006 | 02:42 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You may also look at running a thread of silk around the inner perimeter of the mating surface. This acts as a "gasket" in cooperation with the sealant.
Old Mar 8, 2006 | 09:59 AM
aboatguy's Avatar
aboatguy
Originally Posted by Redeasysport
It tastes like rice
To Rear end RTV
