Help with stamp codes for rear springs
Old Mar 7, 2006 | 06:00 PM
willi.anton's Avatar
willi.anton
Default Help with stamp codes for rear springs
Can you fill in the "stamped codes" for these rear springs? Thanks.
330 lb/in (Z51/Z07) -85, 86, 87, 88, 89, 90, 91, 92, 93
233 lb/in (Base) -85, 86, 87, 88, 89, 90, 91, 92, 93
149 lb/in (FX3) -94
188 lb/in (ZR-1) -94
228 lb/in (Base) -94
327 lb/in (FE7) -94
149 lb/in (FX3) -95
188 lb/in (ZR-1) -95
228 lb/in (Base) -95
327 lb/in (FE7) -95
149 lb/in (Coupe/F45) -96
228 lb/in (Vertte) -96
327 lb/in (FE7) -96
Old Mar 7, 2006 | 06:43 PM
CFI-EFI's Avatar
CFI-EFI
330 lb/in (Z51/Z07) -85, 86, 87, 88, 89, 90, 91, 92, 93 NYU
233 lb/in (Base) -85, 86, 87, 88, 89, 90, 91, 92, 93 NYR
149 lb/in (FX3) -94
327 lb/in (FE7) -94
149 lb/in (FX3) -95
327 lb/in (FE7) -95
327 lb/in (FE7) -96
My parts book doesn't show the spring rates and only goes to 1990. The two codes I could add are for up to 1990 and based on the applications given.
RACE ON!!!
Old Mar 7, 2006 | 07:13 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Ancient Chinese secret.
Old Mar 7, 2006 | 10:22 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
1985 Z51 rear = Nyu
Old Mar 7, 2006 | 10:25 PM
CentralCoaster
How come you don't have 84 on your list?
Old Mar 8, 2006 | 11:16 AM
willi.anton
CentralCoaster the chart is great for relative comparisons. Do you have cross references that list the codes with respective lbs/in specs?
Old Mar 8, 2006 | 02:03 PM
CentralCoaster
No sir, but if/when you find the code info, feel free to add that to my chart.
Old Mar 8, 2006 | 02:14 PM
Vetracr's Avatar
Vetracr
Be careful when comparing just spring rates. What matters is wheel rate, the effective spring rate at the wheel. The 84-87 front suspension is quite a bit different from the 88-96 front suspension. Due to the difference in "motion ratios", a spring for an earlier car has a higher wheel rate than the same spring on a later car. FWIW.
Larry
Old Mar 8, 2006 | 03:09 PM
CentralCoaster
Correct, the mech advantage of the front springs changed in 88. And they aren't interchangeable.
To Help with stamp codes for rear springs
