Having a good timeing
Old Mar 8, 2006 | 02:22 AM
John Pantera's Avatar
John Pantera
Default Having a good timeing
This '87 is my fourth Vette. Has been 25 years since last one and feel like a jerk asking this. I have manuals -- two of them. Something always needs to be disconnected when setting the timeing. Before it was just a vacuum tube now it is "the brown wire."
Found the wire but, for the life of me, can not find where it can be disconnected. It appears to be part of a mass of wires going behind the distributor.
Tempted to cut it and put in a switch but that computer scares me.
HELP?
Old Mar 8, 2006 | 02:36 AM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
Do not cut.
I guess that it is the same at my 84 Vette. At the drivers side above the brake servo attached at top side of the firewall you find a small square flat-top box. It is the map sensor. There is a connector and a vacuum tube connected to it. Close to that box there is a single brown wire with a connector hanging in the wire. That is the one you have to disconnect to set the timing.
Old Mar 8, 2006 | 03:04 AM
CorvAdel's Avatar
CorvAdel
Between the lower part of the wiper motor and the brake booster there is a single brown with black trace wire. It normally is situated next to a black relay(fuel pump), which is attached to the firewall. It has a single plug...disconnect that plug, start the eng., check/set timing, switch off eng. and reconnect plug...and you're set.
Welcome back.....!
Old Mar 8, 2006 | 08:20 AM
JackDidley's Avatar
JackDidley
Welcome back.....!
Brown wire/black stripe. easy.
Nico, would be correct on an 84, but 87 is different.
Old Mar 8, 2006 | 11:30 AM
Nico's Avatar
Nico
Thanks spankyellow. I will remember for the future.
Old Mar 8, 2006 | 11:40 AM
CFI-EFI's Avatar
CFI-EFI
Nico,
The only thing wrong with your instructions was including the MAP sensor. 1984 was the last year for the MAP until 1990(?).
RACE ON!!!
Old Mar 8, 2006 | 12:03 PM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
Don't forget you will need to pull the ECM fuse or disconnect the battery after doing this to clear the 'SES' code on the DIC. (at least on my '89)
Old Mar 15, 2006 | 01:53 AM
John Pantera
Default Thank you
Thanks, guys. Yes, brown wire has black stripe but directions were exellent. I figured I was in the wrong neck of the woods. Has anyone looked at the manuals? They give no clue where the disconnect is located! Wish I still had the '57. That convetible had a trunk!
Vette drivers rock!
To Having a good timeing
