A/C Freezing
Old Aug 13, 2001 | 03:10 PM
95DropTop's Avatar
95DropTop
Default A/C Freezing
I popped the hood the other day after about an hour or two of driving with the a/c on. The a/c hose was completely frozen and had about 1/8in of ice/frost all the way around it. Is this normal? :confused:
Old Aug 13, 2001 | 03:15 PM
olephart's Avatar
olephart
Default Re: A/C Freezing (95DropTop)
I don't think it's normal. When it's happened to me on other cars, it was due to low freon caused by a slow leak.
Old Aug 13, 2001 | 03:17 PM
GlockLT4's Avatar
GlockLT4
You're low on freon (or equiv). This same thing happens in home A/C units. When the level gets low, the pipes will ice up because the freon is depressurizing before it gets to the evaporator. Check your pressure level and add accordingly.
Old Aug 13, 2001 | 03:19 PM
95DropTop's Avatar
95DropTop
Default Re: A/C Freezing (Glock'94)
Thanks, I'll get it checked out :cheers:
To A/C Freezing
