I'm all tingally ......
The wastegate is probably sensing boost directly after the turbo.
In that case the 'boost loss' as the engine rpm increases is probably from restriction in the ducting and intercooler.
That drop is only a few psi and it does not explain the power loss.
At 6000 rpm the engine should make way more power with 13 psi boost than with 8 psi boost.
I think your problem is too much exhaust pressure and you need a bigger turbine housing.
Can you measure exhaust pressure? Weld a feet or two of thin pipe to the exhaust before the turbo to get away from the heat, then use a boost meter.
That's what we came up with too. Hence the q-trim turbine instead of a p-trim and going to a non-divided housing should help too. I acutally take the boost reference from the intake piping directly before the TB. I did this intentionally to get around the boost drop from the intercooler.
I've thought about hooking up a boost gauge to the exhaust setup. But even if I find out that its to much there really isn't anything I can do to fix it. I got the biggest turbine and housing(with in reason) that I could to fit in the space that the kit was designed for.
I'm definately going to stick with the 7psi setting for a while, probably a long time. I think 500+ hp will get me to where I want to be for now. And I'm really sick of blowing up my engines. I just want to drive my car.
