Intermitent no start problem...help!!
Old Aug 13, 2001 | 08:00 PM
Automahn2's Avatar
Automahn2
Default Intermitent no start problem...help!!
OK I have an 89 vette stock L98 6 speed 37k miles. At times when I push the clutch in to start the car nothing happens then after a couple tries the car will start. Was on a run with the club the other day I thought it might be the nuetral switch or the switch down by the clutch pedal so I disconnected the switch and joined the wires together, this should have bypassed the switch right...????? Well I still have to push the clutch in and it hasnt acted up since.....I know its not the vats because it has started and I didnt have to wait for 3 minutes between it starting and not starting.......any ideas?????? :confused:
