Testing Knock Sensor
Old Mar 9, 2006 | 09:06 PM
stonemo's Avatar
stonemo
Default Testing Knock Sensor
DataMaster showed no Knock Count and No spark retard. Changed Knock Sensor and no change. Checked wiring, it looks ok. The car is knocking when hot and going into overdrive. Was wondering how to check the knock sensor system, is it the sensor itself or the wiring or the connector. Looked for an hour for the spark control module, finnally found out my 91 L98 doesnt have one. So its gota be either the sensor, connector, wire or the ECM. Can I unplug the sensor and check voltage without screwing anything up? Not sure where to start. Dont wanta make things worse. Thanks
Old Mar 9, 2006 | 09:16 PM
Morley's Avatar
Morley
Actually you DO have a spark control. It is a small "daughter board" that sits just above the PROM chip in the MEMCAL.
Only way I could think of to test a knock sensor would be to hook it up to an oscilloscope and see if it registers anything when you rap on it.
Old Mar 9, 2006 | 09:53 PM
stonemo's Avatar
stonemo
Watched DataMaster while tapping on the block and sensor itself, Nothing. Now when I installed the sensor I didnt know you were only suppose to tighten it to about 15 ft lbs. Could I have damaged it by over tightening it???
Old Mar 9, 2006 | 09:57 PM
mikey whipreck's Avatar
mikey whipreck
that would have just made it even more sensitive.
Is the chip stock? maybe a previous owner put an aftermarket (custom or otherwise in), that always reports 0 knock.
Old Mar 9, 2006 | 10:09 PM
stonemo's Avatar
stonemo
No aftermarket anything. The knock sensor worked before. Just started getting crappy mileage. So I tuned it up (plugs, wires, cap, rotor, O2 sensor) but still no difference. No codes. Just pings a bit when crusin around. The car still runs good though, idles great and plenty of power, though im a little scared of gettin into it with the pinging. Surely theres a way of testing the wiring and connector to see if thats the problem. Hate to go buy another knock sensor, but I will ... The small daughter board that Morley was talking about, is that replaceable or do I have to change the whole ECM?
Old Mar 9, 2006 | 10:19 PM
Ramanstud's Avatar
Ramanstud
It's been a while since I went through the Factory Service Manual (Where's CFI-EFI???), but I would think you'd eventually get a code if the knock sensor and/or wiring is bad (the ECM periodically checks this).
However, I would try to check continuity of the wiring between the sensor and the ECM first, then go through the FSM on the diagnostic steps. Rule of thumb: check all the stupid, simple stuff first. So clean all connecting terminals, make sure you double-check ANYTHING that you might have messed with before this changed, etc etc.
If it pings around town, that suggests a timing problem which will be different than (but related to?) the knock issue. Could be EST controll or some other thing...
What have you tinkered with recently?
EDIT: You DID double-check your plug wires, right? Really easy to get those backwards - and that causes bigtime pinging under part throttle (ask me how I know!).
regardless, double check those wires again.
Old Mar 10, 2006 | 09:51 AM
stonemo's Avatar
stonemo
Wires are correct, checked them several times. Dont have a Factory Service Manual. Just the Chilton and Haynes manuals, and they dont really tell me much. As far as checking continuity between sensor and ECM, not sure where on the ECM to check. If I disconnected the sensor and turned the key on would I get voltage at the connector? And would It screw anything up to do this? Doesnt the EST controll get its signal from the knock sensor and then adjust the timing? Does the Ignition Module in the distributor have anything to do with the electronic timing advance? I havent tinkered or messed with anything. Did the tune-up to try and solve this problem. It helped some but DataMaster still shows only 1 knock on start and 1 one shut down, nothing in between. Well im gona go stare at it some more and see if anything has changed. Any other suggestions would be greatly appreciated. Im kinda lost here. Thanks
Old Mar 10, 2006 | 10:11 AM
Morley's Avatar
Morley
Well, it is passing the self test then. you said that rapping on the sensor/block registered no knock counts though?
Old Mar 10, 2006 | 10:49 AM
CFI-EFI's Avatar
CFI-EFI
Listen to Remanstud. This whole post screams out for a factory service manual. Not only are all your question answered, there are trouble shooting charts for the various codes and symptoms that may (will) come to plague you while you own this car. It is good to know how your car works.
RACE ON!!!
Old Mar 10, 2006 | 11:10 AM
stonemo's Avatar
stonemo
Nope, Morley, no knock counts. Driving down the road, when it starts to ping real bad, still Datamaster shows no knock counts. And CFI EFI I will have to break down and get a Factory Service Manual as you suggest. Never really had any problems that the chilton or haynes manuals didnt cover. The link that you posted to Helminc.com for the service manual, did I see that right, $95 bucks for the manual? Plan to keep the car for a long time (LOVE MY VETTE) so might as well learn all I can about it. Will invest in one. But in the mean time, should I get another sensor and try it. Was reading in the forums about some electronic parts that were bad straight outa the box. Could mine be one of those? Thanks
Old Mar 13, 2006 | 11:06 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can buy a genuine Helms manual a bit cheaper than that here..
http://www.factoryautomanuals.com/home.php
To Testing Knock Sensor
