Shifter knob removal :6spd
Old Mar 10, 2006 | 11:01 PM
sothpaw2's Avatar
sothpaw2
Default Shifter **** removal :6spd
One last task, if it's easy--and I don't think this is in the Shop Manual--
How do you get the 6spd shifter **** off? LT1 6spd.
Old Mar 10, 2006 | 11:30 PM
FELNGR8's Avatar
FELNGR8
With a screw driver you gently pry off the plastic cover (contains the pattern) in the middle of the ****. Then you look down inside and see a key in a slot of the shifter. Pull out the key with pliers and unscrew the shifter ****.
Don't bonk your head when you pull out the key!
Old Mar 10, 2006 | 11:32 PM
Jerris's Avatar
Jerris
If the pliers don't work, grab it with a vice grip and pry the vicegrip with a screwdriver then unscrew the ****.
Old Mar 11, 2006 | 12:01 AM
Movnviolation's Avatar
Movnviolation
I took an old screwdriver and bent the tip in a 90 degree. It pops the key right out. I am always in the console so I left the key out. The **** does not move!
Old Mar 11, 2006 | 12:30 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
To add, the safest and easiest way is to clamp with some small vise grips and gently tap in an upward direction with a hammer. You won't bonk yourself in the head nor will you put your fist through the roof.
Old Mar 11, 2006 | 09:42 AM
sothpaw2's Avatar
sothpaw2
Ha, Ha, no roof left. Thanks guys, I'll try it and see.
To Shifter knob removal :6spd
