Clutch Adjustment Help
Old Mar 11, 2006 | 02:30 PM
Mike1996's Avatar
Mike1996
Default Clutch Adjustment Help
I have a 96 and the clutch lets out a little to high (I think it may be riding on the throw-out bearing). How do I adjust this? Thanks, Mike
Old Mar 11, 2006 | 02:33 PM
c4cruiser's Avatar
c4cruiser
The clutch linkage is hydraulic and there is no adjustment. You could bleed the system to see if that helps a bit, but it sounds like the clutch disk is getting worn to the point where a replacement is needed.
Old Mar 11, 2006 | 05:58 PM
Mike1996's Avatar
Mike1996
Appreciate the help - wasn't sure if you could make an adjustment - Thanks for the Help!
To Clutch Adjustment Help
