95 code"p" (lt1) running rich
Old Aug 14, 2001 | 01:09 AM
gottaspeed's Avatar
gottaspeed
Default 95 code"p" (lt1) running rich
when accelerating from dead stop more black smoke (fuel) than usual? I was thinking O2 sensors dirty? anyone? anyone?
:chevy
Old Oct 20, 2011 | 04:25 AM
flhx5241's Avatar
flhx5241
id say that is correct.....my 95 done same thing scanned it and read maf and 02 sensor cleaned the maf really good and changed the 02 sensor and good as new
Old Oct 20, 2011 | 04:21 PM
Docderek05's Avatar
Docderek05
I know this sounds lame, but my 1994 manual states to depress the go pedal in park or neutral per trans type, and rev for 2 minutes at 2000 rpm, as a remedy to clean up dirty 02 sensors...now..why a blast down the highway at 2800 rpm does not do the same thing..is beyond me, but I know if the 02's are not working right, a host of settings in the control module are effected, air/fuel ratio, etc. so probably time for either a wiring check, to the sensors, or worst case change em out, and its not a fun job, without a lift, and proper tools, heat, and something to hold your exhaust up as you try to remove the passenger side, I have fairly large hands, you will probably have to drop it down anyway, to get swing clearance to apply any leverage. Make sure you
re-coat the new ones with recommended never-seize.
Best to you, Derek
To 95 code"p" (lt1) running rich
