Fuel Filter Secrets
Old Mar 12, 2006 | 04:10 PM
Yellow95's Avatar
Yellow95
Default Fuel Filter Secrets
'95 6 speed. What's the secret to getting it off? I can't get a wrench on and turn the top nut.
Do you put the wrench on and turn the filter to loosen and tighten the nut?
Old Mar 12, 2006 | 04:20 PM
rick lambert's Avatar
rick lambert
first-you may want to remove your gas cap. second, when I change my filter I put a wrench on both filter and gas line-hold the filter and loosen the gas line, it's a tight area alright-but if I can do-you can do!
Old Mar 12, 2006 | 05:44 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I removed the wheelwell and put a wrench on the line fitting and them back underneath I put the wrench on the filter and turned the filter off.
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Put long tube headers on it. Changing the filter then becomes 10X easier.
Old Mar 12, 2006 | 06:22 PM
froggy47's Avatar
froggy47
Loosen the fuel line guides up top on pass side of engine. This gives you some "wiggle room" down below at the filter.
Old Mar 12, 2006 | 07:59 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Be careful not to strip the line.
Old Mar 13, 2006 | 03:55 AM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
if all else fails you can put vice grips on the filter. you're replacing it anyways. plus use plenty of love juice.
Old Mar 13, 2006 | 07:25 AM
runner140*'s Avatar
runner140*
You need a set of line wrenches (flare wrenches) for the fuel lines and a set of stubby wrenches for the fuel filter.
Old Mar 13, 2006 | 07:34 AM
Mr Mojo's Avatar
Mr Mojo
What I did still seems to be the easiest.
To Fuel Filter Secrets
