There isn't a hose, just a weep hole, about an 1/8 of an inch in diameter on the bottom of the evaporator case. Moisture is good - it means the a/c is working right. If it's leaking into the passenger compartment, then the hole is plugged up. Feel around until you find it and then unplug it with a tooth pick or other soft object.
Moisture seems to be more than normal. Maybe it was just the humidity the past couple of days. I'll see if maybe the hole is plugged a little. No water in the passenger compartment.
