Heads or not...?
Old Mar 13, 2006 | 09:40 PM
I Hate Rice's Avatar
I Hate Rice
Default Heads or not...?
I have 136k miles on my LT1. I contacted AFR last year and they suggested I do a rebuild on the lower end before I got the heads, the gentlemen told me there could be possible leak down on compression....anyone else have high mileage engines that have had aftermarket heads put on? If so any problems? Anything else I should be concerned with in regards to putting new heads on an old engine? Thanks in advance.
Old Mar 13, 2006 | 10:23 PM
bacardioil's Avatar
bacardioil
yes with the new heads the rings will go. man gave you good advise.
regards
Old Mar 13, 2006 | 10:27 PM
Pete K's Avatar
Pete K
regards
Sometimes, you get away with it, and sometimes not. Even a budget re-ring job would be wise. If the bores only have .003 or.004 of taper, hone and rings may be all you need. (other than bearings, gaskets, etc)
Old Mar 14, 2006 | 05:01 AM
SK.LT1's Avatar
SK.LT1
I would advise that if you are going to do a re-ring job you also change out the wrist pins and bearings.New rings would be tighter and the play in the other components that I mentioned could cause some knocking(It won`t be opportunity).Just my opinion.
Old Mar 14, 2006 | 06:58 AM
I Hate Rice
About how much do you think all this preventative maitenance would cost? Just a guestimate would be fine. I'm not the best with a wrench so I would prolly contract it out. Any ideas?
Old Mar 14, 2006 | 07:02 AM
rick lambert's Avatar
rick lambert
besides, once the heads are off it's a snap to pull piston
assembly and more than likley a hone, new rings, bearing and timing chain would be sufficient.
Old Mar 14, 2006 | 07:17 AM
rick lambert
assembly and more than likely a hone, new rings, bearing and timing chain would be sufficient.
Old Mar 14, 2006 | 11:58 AM
95wht6spd's Avatar
95wht6spd
I posted the same question a few weeks ago and every one said the complete opposite. People said it should be fine if it was well taken care of, and you don't spin it to high. There were several that posted and had done heads/cam on high milage LT1 and had no problems. I guess it is a gamble, but if I was going to go to all the trouble to work on the short block, I would get a stroker.
Old Mar 14, 2006 | 12:10 PM
mseven's Avatar
mseven
Most places, reccomend the same. I think if you are going to put that much effort and $$ in it, knowing the bottom end is solid is important.
You can always do a leak down test first.
To Heads or not...?
