Tornado insert
Old Mar 14, 2006 | 10:52 AM
Snuffy's Avatar
Snuffy
Default Tornado insert
Just an update on the Tornado intake insert in my Murano. Most of you won't belive it and won't want to hear it but I believe it did work for mileage improvement. I ran it for about 4 months and averaged about 25 MPG (Imp gallons). After I took it out I averaged about 23 MPG. For me, at current gas prices, that is about $6.42/week. At that it pays for itself in about 3 months. After that it is a pure savings. Not bad as gas prices go up.
I have to be honest, I didn't notice any improved power or performance, just better gas mileage.
I wouldn't put one in the Vette. I am not concerned about mileage there and with no performance improvement it would seem inappropriate.
Old Mar 14, 2006 | 11:04 AM
cv67's Avatar
cv67
St. Jude Donor '05
You bought a Tornado
j/k, good to hear you saw an improvement.
Old Mar 14, 2006 | 09:57 PM
CMYC4's Avatar
CMYC4
I have friend who did one on a North Star caddy, He did pick up 2-3 MPG!
Old Mar 17, 2006 | 07:15 AM
PBA's Avatar
PBA
Is there a website that test these "so called"" gas saving devices? I have heard of these different gas saving devices since I was a kid (late 1950's). But I would like to see some "evidence" on this. Night Owl.
Old Mar 17, 2006 | 09:47 AM
PMD's Avatar
PMD
4th Gear
Sorry to come in as a newbie and be the bad actor, but there is no way that a "tornado" can actually improve performance. It is nothing more than a restriction in the inlet tract. This is mostly a matter of concern at very high rates of flow (i.e. WOT).
It IS possible that you may see a change in mileage. This can happen for two reasons: you are running at lower power/speed (for whatever reason, mostly because you are probably aware that there is some supposed gas-saving device present), or, you PCU is seeing some change in values that is putting it into a more favourable mixture/timing part of the engine map (fairly unlikely, but it IS possible). Any supposed benefit from setting up a different airflow path would be lost in entering the plenum.
Does it not occur to people that all of the time and dollars spent by the OEM and the aftermarket to clean up the airflow to get more mass of air into a cyclinder is totally defeated by adding some kind of obstruction to the system?
Old Mar 17, 2006 | 10:01 AM
jfb's Avatar
jfb
I agree with PMD !!!!!!! Your test was poorly controlled. You can easily see 2 mpg variations even driving the same route everyday, and the pyschological factor to the driver knowing the device is installed affects the outcome. A neutral, unbiased test with an engine on a test stand will prove that putting a restriction in the air inlet will REDUCE the specific fuel consumption (mpg).
Old Mar 17, 2006 | 02:50 PM
Snuffy's Avatar
Snuffy
You are absolutelty wrong. Averaged out over a reasonable time period of several months the result is valid. I will be the first to admit that the numbers are not real accurate but it was an observation.
Anyway, I don't want to get into a P%%ing contest again. We went through this a while back. I was just trying to keep everyone updated and possibly add some information to members of the forum whether you believe it or not.
Old Mar 17, 2006 | 09:34 PM
PMD's Avatar
PMD
4th Gear
I don't dissagree with your observations, I am just trying to bring some understanding to the methodology and discipline required to get the results you seek - and to explain SOME of the possibilities that have generated your observations.
On top of that, repealing the laws of nature and physics are beyond the reach of schlock aftermarket scheisters.
Old Mar 17, 2006 | 10:55 PM
jfb's Avatar
jfb
P.T. Barnum was right !!!!!!!!!!!!!!!!!!!!
Old Mar 17, 2006 | 11:16 PM
DDSLT5's Avatar
DDSLT5
Sucker born every minute! But those things are selling like wildfire!
Old Mar 17, 2006 | 11:45 PM
aboatguy's Avatar
aboatguy
I agree with the self fullfilling prophecy aspect of this test. Someone wants something to work at saving gas. So he/she/it drives for a month or so and subconsiously eases on the gas. Now to prove these results removes the gas tank magnets/tornado/whatever and presses the gas it just a little harder from a start, big surprise there's gas mileage decrease.
Old Mar 18, 2006 | 01:39 AM
jfb's Avatar
jfb
One guess whom they are selling them to.
Old Mar 18, 2006 | 03:26 AM
Demonic85's Avatar
Demonic85
People with big SUV's that already suck a rediculous amount of gas?
Old Mar 18, 2006 | 05:08 AM
goldeneye_vet's Avatar
goldeneye_vet
Well there were folks that were buying up the airfoil like it was going out of style at one time too.
To Tornado insert
