Replacing tail lights and anttena
Old Mar 14, 2006 | 05:59 PM
cal camara's Avatar
cal camara
Default Replacing tail lights and anttena
How do you replace the tail lights on a 1990 corvette convertible. Are they the same as a 1988 model.
thanks cal
ps, how do you get at the antenna.
Old Mar 15, 2006 | 10:41 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Can't help you with the lights, but on my '92 I removed my antenna by lying on my back and unbolting it from around the driver's side rear wheel. If you remove the wheel, you'll gain even more clearance.
Wear some eye protection while you're doing this, though because a lot of dirt and other particles will fall while you're working.
Old Mar 15, 2006 | 11:11 AM
RRT vette's Avatar
RRT vette
You can just take the tag off an this sould give you enough room to reach your arm in there to replace the bulbs.
Old Mar 15, 2006 | 11:25 AM
c4cruiser's Avatar
c4cruiser
Remove the rear license plate and then remove the back-up lamp housing. You can then reach inside to remove the two 10mm nuts that hold the inside lamp housing to the rear fascia. Once the inside housing is out, go thru that hole to get to the nuts for the outer lamp housing.
The best way to get to the antenna is to remove the LH muffler. IT sits above it and while you can go in from the wheelwell, it's much easier to work from underneath it.
Old Mar 15, 2006 | 12:28 PM
cal camara's Avatar
cal camara
Default Thanks
cal
To Replacing tail lights and anttena
