Searching for Idle in Open Loop
Old Mar 14, 2006 | 10:24 PM
90Indy's Avatar
90Indy
Default Searching for Idle in Open Loop
I recently installed a SuperRam along with 30# injectors. I have a chip by pcmforless for the Edelbrock setup with 24# injectors the SuperRam replaced. I have put about 75 miles on the car since the install. What I have noticed is the car seems to be hunting for idle when in open loop. It surges from around 500 - 950 rpm. Once it has gone into closed loop, the problem disappears. I tried resetting the IAC but the instructions in the manual seemed a little odd. "Start car, run for 5 seconds, shut off for ten seconds, restart car".
I don't think at this point it is a vacuum leak as it idles fine in closed loop but I am open to opinions. I will be installing a supercharger shortly and I need to have everything up and running as it should before I start the final phase.
Thanks in advance for your input.
90Indy
Old Mar 14, 2006 | 10:30 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
I usually set the IAC with a scan tool Do you have a datalogging cable? If so send me a datalog and I can send you some pointers. I can also look over and see if we can clean up the tune any.
Old Mar 14, 2006 | 10:40 PM
90Indy's Avatar
90Indy
Hey Alvin,
You burned the chip for my last setup and I fully intend to send you a datalog for this one. I will be sending you a file in a day or two if the skies don't open and dump on me. Hate to wash the car if I don't have too.
90Indy
To Searching for Idle in Open Loop
