Thanks for the help. I really hope the timing cover isn't leaking. From the pictures, it appears to be further up the front of the cover- between the opti and the water pump shaft area. Once I get the opti out, I'll have a better idea of the problem.
Can you explain the WP driveshaft callar installation? I'm doing this without the aid of a service manual. (yes, I will be buying one as soon as a used one appears in the F/S section).
RedEasySport did a nice job of explaining the waterpump seal
If your WP is bad then this caused the WP drive shaft to wobble due the bad WP bearings. This caused the seal to leak around the drive shaft. I own a 93 and I have just removed a bad WP. I discoverd that the WP drive shaft seal was causing my oil leak that showed up a few months ago. My opti almost fell aprt in my hands when I removed it so that I couls replace the seal. I am currently waiting on Dynaspark to catch up on there orders so I can obtain there gen I opti. Hope this helps.
93cruiser
PS. Now I know why some guys go the the trouble of installing an electric WP.
