U-Joints needed, which type to get
Old Mar 15, 2006 | 12:15 PM
Wildcat1's Avatar
Wildcat1
Default U-Joints needed, which type to get
I have found pricing ranging from $10 to $65 for these things. Some are greasable, some aren't. Looks like OE may be non-greasable per Napa's site. Some are anti-galvanic for use in aluminum yokes, is that what I should get? I have a 94 vette. I want the best I can get. I'm replacing the half-shaft u-joints.
Old Mar 15, 2006 | 12:20 PM
Clay Assassin's Avatar
Clay Assassin
I just did mine a few mothes ago, and used spicer.
I actually didnt bother replacing the joints myself.
I removed the shaft, and dropped it of at a driveline service company.
Picked up the same day. balanced, installed, and ready to go.
I think it was 130 bucks total.
I was shocked what a difference it made in the car.
Get a bushing kit before you do the halfshafts, so you can replace some of that stuff too.
Or you may have to go back in again to do it like me.
Old Mar 15, 2006 | 12:22 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
I found spicers at NAPA. Look for ones with the grease fittings on the ends rather than the valley. I wouldn't pay more than $10/$12 each, if that much...
Old Mar 15, 2006 | 06:29 PM
Brimis's Avatar
Brimis
Spicers
Old Mar 15, 2006 | 06:56 PM
prattman's Avatar
prattman
Galvanic corrosion occurs when dissimilar metals are in contact with each other, such as aluminum and steel (Iron).
The Anti Galvanic u-joints are to help that situation.
The reason I bring this up is because the folks at the parts store usually do not now what Anti Galvanic means.
Hope this is of interest.
prattman
Old Mar 15, 2006 | 07:14 PM
CFI-EFI's Avatar
CFI-EFI
Half shafts: Spicer part number 5-800X, 4 used.
Drive shaft: Spicer part number 5-786X, 2 used.
RACE ON!!!
Old Mar 15, 2006 | 11:32 PM
85vet's Avatar
85vet
Cruise-In V Veteran
RACE ON!!!
Especially if you like to drive aggressively.
Old Mar 15, 2006 | 11:45 PM
vader86's Avatar
vader86
You must use spicer, cold-forged with NO zerk fittings.
Anything else is crap.
Old Mar 16, 2006 | 12:22 AM
comp's Avatar
comp
Old Mar 16, 2006 | 10:14 AM
Wildcat1's Avatar
Wildcat1
Thanks everyone!
To U-Joints needed, which type to get
