From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Originally Posted by byebyeL98
My engineering knowledge is quite limited, so please bear with me... Assuming we are able to come up with solid mounting point(s) for some type of "bracing bar", is there any reason why the center section needs to move at all?
The reason I am asking is: I just had a roll bar welded into my '87. Would it be workable to run a solid bracing bar from the center section (possibly around the snout area where the C beam bolts to it), through the rear compartment "floor", to the lower rear, horizontal portion of the roll bar?
Or am I way off base?
Not at all, the only reason it's got bushings in it, is to isolate road vibrations.
For those who have had a diff fail, do you still have the parts? Could you post some pics?
I know one of the forum vendors, if we can come up with a brace/cradle, he's all set to market it.
Are they're any 10sec C4's in the MA area?
My car's engine is still stock, and besides it's still in storage in SoCal.
The vendor's policy is, if we use your car to develope the part, your's is free. I've already got a set of C4 seat rails this way.
I think a trany cross member atached to the frame and the C-beam would help a great deal. If the trany and motor twist is limited or removed then the only twist to he diff would be the flex in the C-beam.
I definitely do NOT have a 10 second car. I'd be thrilled to break into the 11s this year. Too bad I'm not in Mass. (although I'm not too far) - I'd be happy to loan my car for a free brace!
I was just looking underneath the car today - there is SOME room to work under there, and a brace would come up through the body to my roll bar nicely
I was thinking the convertable x-brace as a start. Connect the to back mounts together, and then brace the the diff to these two points. The C channel could also be connected to the X-brace where is crosses underneath, you just need to get around the exhaust.
What exactly did the engineer say? I'm really curious. It seems to me it would eliminate the vertical travel of the diff and it wouldn't break the nose as easy.
Ok...I thought is was the nose of teh diff flexing down under load and the c-beam is the only thing limiting it. Well...looks like cryo is the only solution.
