master Cylinder Question
Old Mar 16, 2006 | 12:11 AM
Quiktrp94's Avatar
Quiktrp94
Default master Cylinder Question
Can you plug the rear brake output port on the m/c and still have the fronts work? I was thinking that I could install a small valve to eliminate the rears for burnouts and launches at the track. I realize that I could use a linelock but thought that this might be another way to go, easier and cheaper. Thanks for any input, Robert
Old Mar 16, 2006 | 04:12 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You could ,but the tech inspector may not let you race,if he catches it.
A line lock is easier and safter.
If you are turning off your ride control.And you learn how to push down on the break and let up for a second and apply it again the back brakes after a certian rpm should unlock the breaks anyway.
Old Mar 16, 2006 | 07:26 AM
runner140*'s Avatar
runner140*
You can but do you want to. When you get to speed, you might have trouble stopping your run. Just my .02
Old Mar 16, 2006 | 10:56 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you have to use the brakes on the strip you'll be sorry. The rears make braking way more stable and of course reduce your stopping distances.
Old Mar 16, 2006 | 11:30 AM
blown87's Avatar
blown87
GA Events Coordinator
and i will add, DO NOT DO THIS!
Old Mar 16, 2006 | 06:47 PM
Quiktrp94's Avatar
Quiktrp94
Thanks guys, I figured it wasn't the way to go, but couldn't think of all the reasons not to. You have enlightened me on why not to do it. Robert
To master Cylinder Question
