Injector ??
Old Mar 16, 2006 | 02:09 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Injector ??
What size injectors are stock on a 93? I have heard 22 and 24 pounds.
Old Mar 16, 2006 | 03:02 PM
bobmic93's Avatar
bobmic93
They are 24lb. I have a perfectly good used set with 50,000 miles on them if your interested. Im not looking for alot of money either. I put in 30lb along with new top end. Ya, but they are 24s
Old Mar 16, 2006 | 04:32 PM
93 ragtop's Avatar
93 ragtop
Technically, according to a scan of the orig. chip programming it is 23.8lbs. Now I think where the confusion comes in is this. Factory injectors are rated at 24 (23.8) lbs but this is at 43psi pressure. When using an aftermarket injector such as the ford svo injectors, they are 24lbs but at 38-39lbs pressure. So at the set pressure of 43 they are more around 26lbs give or take a little.
Old Mar 16, 2006 | 07:53 PM
Lichen's Avatar
Lichen
Buy Ford (Bosch) blue-top 24# injectors. '93 was one of those years when they used some brand (I can't remember the name), that just weren't that good (but better than Accel). Do an internet search and find the best price (you don't need the overpriced "matched" set).
Old Mar 16, 2006 | 07:59 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I have a set of FMS 24# for sale in the parts section.If you do not use an AFPR they may run rich although some people report no issues.
Old Mar 16, 2006 | 08:56 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I run LS6 injectors. At my LT1's stock pressure, they are supposed to be around 25.8#, if memory serves. If I were to boost the pressure to LS6 specs, they'd be 28# injectors.
The computer should compensate for this within a little while after installation if all's well.
Old Mar 16, 2006 | 09:14 PM
Mkos1980's Avatar
Mkos1980
I assumed 92-93 were 22lbs.
To Injector ??
