motor swap ?
Old Mar 16, 2006 | 02:21 PM
r6crovetteman's Avatar
r6crovetteman
4th Gear
Default motor swap ?
Hey guys I need a little advise
I have a 84 auto that I built a 400 sb heads cam everything (engine dyno it made 487 hp) and I put a carb on it but I don’t use the car anymore because I broke to many trans and rearends and I had to work on the car more than drive it.
I just picked up an 89 stick and launched the engine. I want to put my build 400 in it because im sure the car will hold up a little better with the stick and 44 rear. I don`t mine buying an accel super ram if that is all I need
Is this a good idea or no ??
And if so do u think all I need is the super ram, throttle body, injectors, & pump ??
