Newbie Shift Question
Mar 17, 2006 | 07:59 AM
2nd Gear
How do I get rid of that annoying forced first to fourth shift on my '94 six speed? Please Help!
Mar 17, 2006 | 08:03 AM
St. Jude Donor '14
Rev higher.
There are bypass kits at any of the parts websites too.
Mar 17, 2006 | 08:13 AM
Quote:
unplug it
Mar 17, 2006 | 09:18 AM
2nd Gear
Where
I've heard that you can simply unplug it, but where? I assume a plug somewhere on the trans?
Mar 17, 2006 | 10:36 AM
From: The reason time exists is so everything doesn't happen at once
The 1 to 4 shift was designed to increase fuel economy. It prevents you from shifting into 2nd or 3rd gear at low speeds. You can unplug the connector at the trans, or just nail the gas.
Mar 17, 2006 | 10:54 AM
Unplug it at the trans. it is the middle wire on the drivers side.
Mar 17, 2006 | 12:25 PM
Get one of these:
CAGS eliminator
Mar 17, 2006 | 01:01 PM
drive through it, it cuts off over 2x mph, just accel to redline and powershift into 2nd, it's mandatory anyway (this coming from the guy with no 2nd gear synchronizer).
Mar 17, 2006 | 01:18 PM
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Third option: Pull the fuse. It's #26, IIRC.
NOTE: The BEST option is the CAGS eliminator.
It's quick, simple, cheap, clean, neat, and doesn't throw a code or affect anything else.
Larry
code5coupe
