Failed emissions 1986
Old Mar 17, 2006 | 12:06 PM
Bear86's Avatar
Bear86
Default Failed emissions 1986
The CO is 1.43 should be less than 1.20. Any ideas?
Thanks Larry
Old Mar 17, 2006 | 12:21 PM
TM-Z06's Avatar
TM-Z06
List your modifications. How old are your catalytic convertors? Also, when was the last time you changed the following - fuel filter, O2 sensors, EGR valve, spark plugs, wires, cap and rotor???
Old Mar 17, 2006 | 01:58 PM
86PACER's Avatar
86PACER
Did you arrive with the car hot?
Old Mar 17, 2006 | 02:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
1 quart of denatured alcohol (4.95 at Wallmart) to a full tank of gas. Its a bandaid, but it works.
Old Mar 17, 2006 | 03:00 PM
jcsr72's Avatar
jcsr72
You need to be in tuned up shape, have a 195 degree thermostat, a HOT (not warm) engine, decent cats. Have you removed any emmisions equipment? Also, scan the ECM, it may be throwing a preliminary code.
Old Mar 17, 2006 | 05:37 PM
blown87's Avatar
blown87
GA Events Coordinator
what are the rest of the #'s
To Failed emissions 1986
