door hinge repair
Old Mar 18, 2006 | 10:55 AM
blown66's Avatar
blown66
Default door hinge repair
Anyone ever used those door hinge repair kits? My 92 driver door is loose and I am debating on new vs repair.
Old Mar 18, 2006 | 11:58 AM
LD85's Avatar
LD85
I am about to do this too, any info would be much appreciated!
Where do you get the hinge repair kit at?
Old Mar 18, 2006 | 12:29 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I haven't put any on a Vette but have installed these on other GM cars over the years. Installed properly, they will make them as good as new.
Old Mar 18, 2006 | 02:23 PM
corvette1989bham's Avatar
corvette1989bham
If you do this job PLEASE take step by step pictures and share the story!
Old Mar 19, 2006 | 08:25 AM
LannyL81's Avatar
LannyL81
The driver's door on my 96 had a worn pin/bushing on the bottom. I just bought four new hinges from gmpartsdirect.com and replaced all of them. It was not too bad....just replace one hinge at a time and support the door end with a thick pad and a small floor jack. The passenger's side went with no problems, but the driver's door slipped off the jack and it took me three times to get the door aligned again. Which is just a matter of "trial and error" getting the fit just right.
The problem with replacing the pins/bushings is that the pins have to be cut below where they have been flatten, in order to drive them out. Can't do this on the car, so the hinge has to come off. Again, not hard to do, just remove the lower body panel to get access to all bolts. I cut the pin on the worn hinge just to see how difficult it was and was going to get one of those kits off of ebay...but never did. I have four extra hinges sitting on a shelf...maybe some day I will replace the pins/bushings and sell them...except that after adding the cost of the kit and something for the hinge itseld and my labor....its more than the price of a new hinge from gmpartsdirect.com...even with their shipping.
Oh... and the upper and lower hinges are the same for both sides....just that they are upside down between sides. And the new hinges are black, not the body color.
Later,
LannyL81
To door hinge repair
