My 86 has been showing the Low Coolant Light on recently, and the levels, both in the Radiator and Overfill are correct. Hasn't been changed in over 2 years. It only does it when the engine is warm and goes off when going up or down a hill. The Temp is normal at around 180. Any ideas why it is on ? Puzzled !
The engine is lower than the radiator in C4's and with the engine off and the radiator cap removed, the coolant looks full but there is an air bubble in the block and when the water pump starts moving the coolant, the coolant level drops and turns on the low coolant light. I agree with Vader86, fill your radiator with the engine slightly racing and up to the opening temp of the thermostat, then put the radiator cap back on and let the idle speed back down.
It depends on the amount of coolant in the system. I've had the coolant level in my 87 be a good 5" below the filler neck and I never saw temps much above what the car usually runs at. As long as there is coolant flow and the radiator can effectively cool the liquid, it should be OK.
Cooluing systems probably have more than enough coolant to keep an engine at the correct operating temps.
After a dozen+ years of early style C-4's [overflow ahead of front wheel] I'm resigned to fact that occassionally if car hasn't been driven for awhile I'm going to have coolant warning light! Have tried new sensor and a few other recommends. Never seem to hear this complaint once overflow tank went back to cowl upper right hand side.
every time i drop the coolant to service something, it takes about a week of adding a tiny amount of coolant to a ''full'' system before the low coolant lite gets tired of the game....normal,irritating,but normal.
coolant 2 years old is about ready to be replaced anyway...it turns acidic and begins to digest things,especially aluminum things like radiators and cylinder heads
After 20 years of C4 ownership, I have never had that problem. I would suggest you check your radiator cap and the radiator where the cap seats.
You need to learn how to pack or burp your cooling system. With the engine warm enough for the thermostat to be open, and the engine idling with the cap off, raise the engine rpms to about 2000. You will see the water level drop. With the rpms still elevated, top off the cooling system and install the cap. THEN you can allow the engine to return to a normal idle. I usually check mine again after it has cooled, with the engine off, and it is usually possible to add a little more coolant. It doesn't hurt do do all that while the front wheels are on ramps.
Much lower than that and your gauge will read "Cold". There won't be enough coolant to reach the sender.
The light still goes on and I have noticed after I shut off the engine, there is a small puddle of Coolant that is leaking from the Rad. Cap. Going to replace it and see if the light stays off. Otherwise, got to be a Sensor problem.
Anything that will allow air to be sucked in on cool down will cause this. Replace the cap, it sounds defective. Also double check each and ever hose clamp to be sure it is tight.
Well a new Cap fixed the leak, but the light still goes on but randomly. Doesn't always stay on, only every once in a while. I am thinking the Sensor. But, since the coolant will need changing soon, should I change it first and then see if the problem goes away ?
Do you nedd to remove the Knock Plugs when changing the coolant on an 86 ? I have been told not to use a Flush treatment and only use water to flush clean.
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Sometimes the coolant sensor gets crud around where it plugs into the radiator under the cap, or just gets a coating on the sensor itself. Notice that it has only one wire, so it is very sensitive to proper ground issues. I'd try pulling it out and cleaning off the sensor and the area where it screws into the radiator real well. Make sure it is clean and tight when you put it back into the radiator housing. Easy 10 minute job and often fixes this type of issue. Then be sure you properly purge/burp the system again as you will allow air into the radiator doing this.
John, The guys have already covered this in detail, but just for your reference, here is the TSB (Technical Service Bulletin):Low Coolant Warning Light
The clamps on the hoses to the recovery tank are important as when the engine cools, it tries to draw the coolant expelled into the recovery tank back into the radiator. If the clamps aren't good and tight, the system will suck air into the system, but not leak coolant. The results are the same, LOW COOLANT light.
