24# SVO Injectors?
Old Aug 15, 2001 | 12:50 AM
Midnite 88's Avatar
Midnite 88
Default 24# SVO Injectors?
2 simple questions:
Can I run these on a bone stock motor?
I read that someone here got a set for $150.00?
Where can I get these for $150.00/set?
Any other recommendations?
Okay so..... 4 questions.
TIA, Mike.
Old Aug 15, 2001 | 12:52 AM
91-Z07Coupe's Avatar
91-Z07Coupe
Default Re: 24# SVO Injectors? (Midnite 88)
I've been looking for this information as well. I'm sure someone will post the info.
Old Aug 15, 2001 | 01:06 AM
h rocks's Avatar
h rocks
Easy, in your case, yes. Dunno about $150, but around $200 should be doable. Jeg's and Summit sell them for ~$230, but if you can stomach reading a Rustang rag, many of the 5 Liter mail order houses seem to use the SVO injectors as loss leaders to get these guys to start doing business with them. I've seen $199, but it's been a while since I took Pepto Bismol. :U
[Modified by h rocks, 12:07 AM 8/15/2001]
Old Aug 15, 2001 | 01:15 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You should use an AFPR to adjust fuel pressure to account for increased flow of these larger injectors.
Or you can send stock injectors to Rich to be fully reconditioned for about $80, at http://www.cruzinperformance.com/
Old Aug 15, 2001 | 02:00 AM
MCPOWHITE96's Avatar
MCPOWHITE96
Default Re: 24# SVO Injectors? (65Z01)
The only time the higher flow injectors really give you any probs is during WOT operation. Long as its on an OBDII car, the ECM is smart enough to compensate during normal driving. Been driving with them and stock FPR for about 9 months now with NO probs. Look on ebay.
Old Aug 15, 2001 | 03:00 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You can use them. I would reprogram the ECM if they are 10% higher flowing over stock.
Old Aug 15, 2001 | 04:25 AM
88sk's Avatar
88sk
I got #24inj. from mt. laurelmustang(theyre in pa.) for $185. a few months ago havent installed yet(gonna do accelbase&inj., slp runners&waterpump this wk.) :crazy: :crazy:
Old Aug 15, 2001 | 10:54 AM
DarkRose94's Avatar
DarkRose94
Default Re: 24# SVO Injectors? (88sk)
Are stock injectors 22 or 23#?? I can't remember what they are!
:smash:
:crazy:
Old Aug 15, 2001 | 11:07 AM
Chris@SD's Avatar
Chris@SD
Default Re: 24# SVO Injectors? (DarkRose94)
Stock injectors are 24#. The reason that they are different from the SVO injectors is GM rates flow at 44 PSI where Frod rates is a ~36???
You can use them with the stock programming, but it is NOT A GOOD IDEA! You really ought to reprogram your computer for them.
Good Luck,
To 24# SVO Injectors?
