Can anyone tell me the amperage rating of the fusible link located at the starter?
While checking my spark plugs I noticed that my link is showing signs of heat distress from the #8 header pipe. I plan to change it before I end up getting stranded.
When you buy fusible link wire, it is sold by the guage it is intended
to protect. In other words, if you pick up a piece of "12GA Fusible Link"
material, then strip off the insulation and measure the conductor with
an AWG - it should physically measure 16GA.
Since you are concerned about the FL for the starter, here is another
thread that may also be of interest.
