Cut Lid Question L-98
Old Mar 19, 2006 | 03:39 PM
flatbush862's Avatar
flatbush862
Default Cut Lid Question L-98
In some of the posts, the members talk about "cutting the lid" for the air cleaner box to pull in more cold air. Where is the section cut? At the fan shroud?
Flatbush862
Old Mar 19, 2006 | 03:51 PM
vader86's Avatar
vader86
Take off the air lid, and cut a big square hole in it exposing the entire filter surface, then bolt the lid back down.
Old Mar 19, 2006 | 03:58 PM
flatbush862
Default Cut lid
Vader -
By the lid do you mean the box that holds the air cleaner that is removed with the thumb screws? If so the cut is on the face up exposed side or face down side?
Old Mar 19, 2006 | 04:00 PM
vader86's Avatar
vader86
You dont touch the filter housing that is bolted to the radiator, only the lid attached to it that covers the filter.
Old Mar 19, 2006 | 04:01 PM
flatbush862
Vader-
I'm still learning to navigate the site so bear with me -
By the lid do you mean the box holding the air filter that is removed with thumb screws? If so, cut the top (exposed side), or bottom?
Flatbush862
Old Mar 19, 2006 | 04:03 PM
flatbush862
OK I'll take a look
Old Mar 19, 2006 | 04:06 PM
vader86's Avatar
vader86
Originally Posted by flatbush862
OK I'll take a look
just remove your air filter
in one hand you'll be holding the lid, and the other you'll be holding the filter
Old Mar 19, 2006 | 04:58 PM
RRT vette's Avatar
RRT vette
Vader-
Flatbush862
It's the rectangle shaped black metal piece with vents that hold the air filter in place with finger bolts. Just cut a square, almost the same size as the filter, around the vents. Not the fiberglass piece with the neck that holds the air filter and bolts on to the radiator housing.
Old Mar 19, 2006 | 04:59 PM
L98Corvette's Avatar
L98Corvette
Flat you will cut the side out that has the slots in it, the top side.
To Cut Lid Question L-98
