Pros & Cons
Ken
when I was building my engine the machine shop somehow put mne in the retard slot and caused all sorts of problems, puking gas out the intake, valves slapping pistons, all sorts of nasty shiite. Put it back to OEM slot and it started right up. I wouldn't fool with it unless you are absolutely sure of the results.
RACE ON!!!
ALL manuf. of cams have different methods of grinding cams. Sometimes I do not even think they know themselves. Been told one way and found it to be something different. What I am talking about here is whether or not the cam has the 4* ground into it that some here are talking about or not. Some companies do, some do not.
Some other things that you MUST realize when putting a cam in is your relying on SEVERAL things to be right in order to get your cam in at the CORRECT angle.
(1) The keyway in your crankshaft relative to TDC
(2) the keyway on the crank sprocket
(3) the pin location/bolt holes on the cam sprocket
(4) the dowel pin/bolt holes on the cam itself
(5) shouldn't be an issue, but can be if your not using new stuff and that is timing chain stretch. that alone can put you off SEVERAL degrees.
But as you can see your ASSUMING a bunch when you just slap the cam in at the 0* mark.
The absolute proper way to do it is DEGREE THE CAM. The manuf. of the cam will give you a specific angle that the cam should be degree to. My latest cam is 104*. This is degrees required for the intake valve to travel from .050 before and after max lift for my cam.
If you get anything other when you degree your cam from the number specified, you NEED to adjust it. You adjust it by using the different keyways on the crank. Most nowdays have 3 setting. 4* adv; 0*; and 4* retard. REMEMBER that 4* on the crank will only change the cam 2*! Its a 2:1 ratio.
Some of the better timing chains have a hex-adjust setup or have MANY keys. I like the one that has many keyways. Basically it has 2* increments or as mentioned above, you can make adjustments as little as 1*.
There is no excuse not to degree your cam. Its the heart of the motor!
street engines or race... there is MUCH to be gained by properly timing the valve events.
if you have no idea of what you're doing, put it in ''straight'' up....if you know you're building a torque monster (all l98's) advance it at least 4*....if you're gonna buzz it 8 grand+ on the strip, retard it at least 4*...
record what you set it on so later on you can fatten up the bottom or the top by changing the cam timing.
moving the cam will alter valve/piston clearance--not usually a problem with street cams and pistons, and on race motors you should check clearance in advanced and retarded positions so that you can safely reset later without hitting the pistons
btw- i just did a bbc a couple days ago and the 4* marks moved the cam 8*...don't know where the guy bought the set but it was true rollers and looked ok...without degreeing it things would have been weird
