Header Install - Touching Slave Cylinder
Old Mar 20, 2006 | 07:08 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Header Install - Touching Slave Cylinder
These headers are EM's off of an LT1.
They are touching the slave cylinder. They fit, but I'm not sure I like the idea of them touching, especially since I had to take the heat shield off in the first place.
Can I bend the collector down? Any other suggestions.
Old Mar 20, 2006 | 11:17 PM
Slalom4me's Avatar
Slalom4me
No, they don't.
My vote is that you won't get much movement, nowhere near
enough. Close proximity to the collector is a problem, touching it is a
show-stopper.
Short of an involved reworking, the best plan might be to locate pipes
that are a better fit for your configuration and offer those ones for
sale to someone who can use them.
Is there a part number on them? I wonder whether they are intended
for an A4 car?
Old Mar 20, 2006 | 11:21 PM
Pete K's Avatar
Pete K
If you are forced to make them work, whack a healthy dent in them to give as much clearance as possible. Then wrap the slave with thermo-tec.
Old Mar 20, 2006 | 11:54 PM
Slalom4me's Avatar
Slalom4me
Well, if it comes to that, remember to find something to fit inside the
end of the collector first so as to hold its shape and make it easier to
complete the rest of the exhaust.
Heating up the collector (off the car), ala the blacksmith's approach,
will make the job go easier and possibly make for a tidier 'mod'.
To Header Install - Touching Slave Cylinder
