which garretts
Old Mar 21, 2006 | 12:45 AM
Getsom's Avatar
Getsom
Default which garretts
Hi all,
l have dicided, to purchase two brand new garrett turbos for my chev can some please give me some advice on which models l should purchase.
l am also planning to use a scat crank and rods rebuilding the motor taking the engine up to 383ci.
thanks getsom
Old Mar 21, 2006 | 09:42 AM
Baldturbofreak's Avatar
Baldturbofreak
Garrett GT3571's internally gated. PM sent.
Old Mar 21, 2006 | 01:19 PM
mn_vette's Avatar
mn_vette
Have you figured out where you are going to put them?? twins are a little tough. Lets hear the game plan
You may just want to buy one and then see if it'll fit on both sides and then get the next one.
Old Mar 21, 2006 | 06:35 PM
compulsivehp's Avatar
compulsivehp
Good call! I have seen this turbo alone put out 500hp on a 2.5L and would be a sweet set-up on a TT V8.
Old Mar 21, 2006 | 06:50 PM
Baldturbofreak
Not to mention internally gated for space, and quick spool for street.
Old Mar 22, 2006 | 04:29 AM
Getsom's Avatar
Getsom
is this the correct model ?
GT3571 1.05 & 1.18 Ex A/R 71mm Comp
Product details
Part Number: GAR-731413-1
THANKS FOR ALL YOUR HELP GETSOM (Australia)
Old Mar 22, 2006 | 09:26 AM
Baldturbofreak
ooops my bad, the internally gated one is the Gt3271. The Gt3571 is free floating.
http://www.turbobygarrett.com/turbob...1_452203_1.htm
Is the Gt3271.
A pair of those babies will do you well, and save you some hassle with the internal gates. They cost $880-1000 pending on where you go and there is 3 turbine housings availible. 0.78,0.69 internal, or 0.78 free floating.
Here is the plot on the turbocalculator:
http://www.not2fast.com/turbo/glossa...orDutyCycle=85
You have to click on Gt32 on the map scroll bar. but it will allow you to check it on various compressor maps. For street use you'd like too have the maxiumum compressor effciency occur around the torque peak. which pending on cam selection (stay mild with reverse split) will happen with these.
Have fun!
Old Mar 29, 2006 | 12:00 AM
JA94vette's Avatar
JA94vette
Where is a good place to buy turbos and other related parts. Just want to start doing some research.
To which garretts
