391 cubic inch small block? ? ?
Old Mar 21, 2006 | 07:47 PM
Hole-Shot's Avatar
Hole-Shot
Default 391 cubic inch small block? ? ?
I came across an 87 vette for sale with a 391 cubic inch motor. What is the recipe to build a SBC and come out with 391 cubes?
Is the build a lot different vs a 383?
Thanks.
Old Mar 21, 2006 | 08:07 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm guessing a 3.875 crank and standard bore.
Old Mar 21, 2006 | 08:10 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I think it is a 3.8 stroke with a 40-60 over bore. I have noticed that some people measure bore by piston size and some by actual bore of the cylinder.
IMHO
Old Mar 21, 2006 | 08:21 PM
Corvette Kid
Actually it figues out closest to a 3.875 w/ a .010 overbore. A 3.80 w/ a .040" bore is under 390 and with a .060" bore close to a 394.
Old Mar 21, 2006 | 08:23 PM
Jerris's Avatar
Jerris
Sounds like a 396 SBS with 0.30 less overbore.
Old Mar 22, 2006 | 12:56 AM
johnnyevans's Avatar
johnnyevans
Bore X Bore X Stroke X 0.7854 X # cyls = cu in displacement
4.001 X 4.001 X 3.875 X 0.7854 X 8 = 389.753203547 cu in
4.020 X 4.020 X 3.875 X 0.7854 X 8 = 393.46372296 cu in
4.030 X 4.030 X 3.875 X 0.7854 X 8 = 395.42368866 cu in
4.030 X 4.030 X 3.75 X 0.7854 X 8 = 382.6680858 cu in
4.030 X 4.030 X 3.80 X 0.7854 X 8 = 387.770326944 cu in
Whew! Too damn much math, especially on your fingers !!!
johnny
get em' chris
My new project
4.125 X 4.125 X 4.00 X .7854 X 8 = 427.6503 cu in
I rounded down cause 428 sounds like a ford.
Old Mar 22, 2006 | 01:00 AM
Demonic85's Avatar
Demonic85
i have a SMC 350
I havent the slightest clue as to how you guys come up with these weird engine sizes.
Old Mar 22, 2006 | 01:01 AM
johnnyevans
There you go 4ever21
Old Mar 22, 2006 | 01:25 AM
Sinister87's Avatar
Sinister87
I have a 396 in my 87 vette, 3.875 stroke, with a .30 over bore. In my 87 t/a, I have 383 with a 3.80 stroke and a standard 350 bore.
Old Mar 22, 2006 | 01:29 AM
johnnyevans
In the 87, a GM crate or did you build it? The crates a darn good place to start
Old Mar 22, 2006 | 01:50 AM
Demonic85's Avatar
Demonic85
If I ever do mod my Vette, i'm keeping a 350 as the base. Not necessarily the stock 350, but I dont need anything bigger lol.
Old Mar 22, 2006 | 02:36 AM
pablocruise's Avatar
pablocruise
I have one. Crank is 3.835 throw, with 6" H-beams, and pistons are .030 over.
It's for sale too
http://classifieds.nitromater.com/sh...2&cat=3&page=1
Old Mar 22, 2006 | 10:23 AM
Jerris's Avatar
Jerris
It's for sale too
Now we know.
Old Mar 22, 2006 | 10:48 AM
Gold1986Vette420's Avatar
Gold1986Vette420
It's for sale too
Seems like an awful lot more trouble to gain only 8 more cubes.
More so than buying a Stroker kit like I did.
Old Mar 22, 2006 | 11:33 AM
johnnyevans
Yep, went to small journal rods, slows bearing speed a wee bit.
If he'd stayed large journal, the crank would have had to be welded, which would have been a real waste, probably still had to go 0.040 under on the rod bearings. Expensive way to do it, unless the crank had a journal nicked and had to be cut anyways and you picked up the crank real reasonable.
To 391 cubic inch small block? ? ?
