Memory issues ANYBODY
I have had a very similiar situation with my 93LT1 VERT, this car has been down since 10/09/2005, it has had 3 different shops to work on it, and now I am confident this shop will resolve my Issues.
1. Car has had several 4-5 ECMS installed work intermittenly and shut down.
2. CCM replaced to no avail.
3. Serial data loss
4. wiring harness issue.
At this point my mechanics says there is so much corrupted info between all 4 systems this car is severly confused. It sees different info everytime it goes into startup mode. He will have to reprogram several times in order for the car to recognize what it should do consistently. He has by passed all vats issues and currently has a key fob programmed and it works car didnt have a fob when I purchased it.
FEED BACK PLEASE Thanks KRYPTONITE
__________________
1972 LS5 ASPHAULT EATING SHARK
3. Serial data loss
At this point my mechanics says there is so much corrupted info between all 4 systems this car is severly confused. It sees different info everytime it goes into startup mode. He will have to reprogram several times in order for the car to recognize what it should do consistently. FEED BACK PLEASE Thanks KRYPTONITE
2.) If the ECM and CCM were both replaced to no avail, you have a wiring issue with power shorting them out or doing something "illegal" with respect to input voltages. It may be time consuming, but voltage levels and grounds need to be checked at each ECM terminal.
I am not an expert, but I know of NO reason why your machanic would need to reprogram the ECM/CCM more than one time. WHAT is causing the programming to become faulty? It should NOT happen unless there is a significantly incorrect wiring issue corrupting the programming. You solve that, you solve the programming issue.
Ease Diagnostics sells emmissions control software including the software and hardware to Flash reprogram the GM ECM and CCM in 93 and later cars.
On-Board Programming (In Vehicle):
- 1993 and newer GM Powertrain/Body/Chassis flash reprogrammable controllers
- 1996 and newer Saturn Powertrain/Body/Chassis flash reprogrammable controllers
Off-Board Programming:
- 1993 and newer GM Powertrain flash reprogrammable controllers
Their systems use GM supplied bins and are certified in several states for official use as well as by GM. You might send an email to the Emissions Products Sales people at Ease. emissions@obd2.com
Ask if they have sold to a shop in your area that does flash reprogramming. Call that shop and see what they say about the reprogramming issues you are having.
3. Serial data loss
__________________
The way the system is partioned and based on what the ECM versus CCM tasks, it is very unlikely the system is confused. If the serial link is down, the CCM will set a code and will not be able to communicate with the ECM and the EBTCM.
If the serial bus fails while driving, the car will not shut down if engine is on. Turn the key off and the car will not restart until the com link is re-established (part of the security logic).
Sounds like a better diagnosis than the Corvette Alzheimer's tripe from the mechanic.
It appears you have an intermittant connection problem and a bad ground will cause the ECM to shut down and not communicate to the CCM
