hesitation woes
Old Mar 22, 2006 | 06:52 PM
84lvnlg's Avatar
84lvnlg
Default hesitation woes
When full throttle, lift - brake, then full throttle my '84 crossfire will hesitate and often as not stall. Any suggestions? Stock engine auto.
Old Mar 22, 2006 | 07:03 PM
CFI-EFI's Avatar
CFI-EFI
Probably the most likely culprits are the IACs. You can pull them and make sure the air passages leading to and from them are clean. While you are at it, its a good idea to check and confirm all the tune up adjustments, timing, TPS, etc. Especially the minimum air adjustment and the balancing of the TBs.
RACE ON!!!
