My '91 used to do the same thing.
Try removing and cleaning the contacts.
I think there was a tech tips on how to do this here on the forum
Tech Tips >> C4 Related Tech Tips >> Fixing an erratic 90 to 95 digital display
What I've read elsewhere on this board is that over time the pins in the connectors oxidize and eventually lose contact. If you drop the sterring column and remove the bezel the insturment cluster will unplug from the dash panel. On top of the cluster is a connector where the LCD display plugs in. You can slide that back and forth about 1/32 of an inch. Many times that will break the oxidation layer and restore contact. You may also want to get some contact cleaner from radio shack and lightly spray the connector as you do it. I'd clean the main connector as well.
This worked for me. My display was half missing and difficult to read. Once cleaned its been solid ever since.
Unless you are electrically inclined I'd refrain from disassembling the cluster. However there is a tech tip on doing that on the in the C4 tech tips section with some detailed instructions and photos.
Use Bryan at BATEE@COM and he is clearly the best in the business! Bryan is "The Man" when it comes to digital dashboards and other devices. We in the Corvette world "need" people like Bryan so please support him and recommend him to anybody with a C4! It is in our best interest to keep Bryan in business!
I did the work myself with the parts and support from Batee.com and it was not too difficult if you know how to solder and de-solder. I was shocked to find burn marks on the PC boards caused by the light bulbs that GM used originally. After upgrading to BATEE.COM bulbs I doubt it will do any more damage.
I found the plastic connectors on the boards have warped and this causes the erratic action you are describing. The wires of this one particular connector were not making any connection in the center of the strip as the plastic had warped so badly. I used to have to tap the dashboard to get connections but not anymore. I also rebuilt the C68 A/C controller while I was at it. Now I have a fully functional dashboard and AC controller in my 1988 C4 thanks to Batee.com.
